oil in combustion chamber.....fixed see how.....
ok so after getting some work done by Missisauga engines (canada) on my head.
nothing major just new valve springs and valves, i had burning oil problem and major oil in the combustion chamber #4 , after not having any problems at all with the oil before, and the motor was rebuilt 1 year ago , so after a leak down test and compression check everything was really good (3% leakdown), i bring it buy the "shop" tell him i have a problem , seemed like valve seals at the time because of big cloud of smoke in the morning, so i had to take apart the motor for him to do the seals , myself? so i did the seals were ok , so i put it back together.
i take the head off the next day again , bring it to the shop the day after, he says everything is good they can't find a problem , i say what about the valve guides ? he says no way there good,
i put it back on again same **** , the problem is there was so much oil on the spark plug it was clumpy!!!,
a wait a week , take it to a fellow mechanics shop, we take the head off again this time i take the valve springs out myself and check the guides, i get alot of play, i send it back to them, they say its good, "but do me a favour and take a piston out to check the rings and such", at this point i say ok whatever, i do it, nothing wrong with the rings, but the guy sent someone down to check the bore, he says out of round 2 degrees, i say so i didn't have these problems before the work on the head, so he replaces the guides in that cylinder just to "make me happy" i put everything back together and guess what......
ALL FIXED good to go, moral of the story, machine shops never will except responsibility, even when a mechanic can proove he is right!!!!
anyone in ontario, don't deal with MISSISAUGA ENGINES UNLESS YOU WANT PROBLEMS, this is not the first horrer story i found others if you would like to hear
Re: oil in combustion chamber.....fixed see how..... (AllMotorMark)
Did you have smoke when you accelerate the car full throttle? How much oil did you burn every 500 miles?
So true
So true
Sassafrass
20
07-18-2006 07:06 PM
