painting a header?
painting a header?
I know there is paint for an engine block. Is there paint for headers? I'm not sure.
The reason I ask is because I live in Cali. I have 2 DC headers, 1 has a CARB tag for a stock 2000 Si, and the other does not have a CARB tag (race only, type-r, 2.5")
My question is - can I grind/remove/swap the CARB tag from the legal header and tack it on the type-r header? This would be obvious, considering you'd see fresh welds on a ceramic-coated manifold. That's where the paint comes in - if I can do a clean swap with the grinds/welds, and then perhaps paint the header black, it might look a little more legit. I know I'm stretchin it here, but I'm still lookin for the collective knowledge of this forum to help combat my ignorance.
Thanks!
Thanks!
Re: (jdm420da6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm420da6 »</TD></TR><TR><TD CLASS="quote">i tried painting my header and that **** did not work...it just flaked off.</TD></TR></TABLE>
same here
same here
1 Post
Header temp reaches somewhere in the vicinity of 1200 plus degrees. I have tried in the past with the highest temp paint you can buy to paint them black, nothing will stay and your car will reak of burnt paint for a good two or three days.
Re: (rtzcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtzcom »</TD></TR><TR><TD CLASS="quote">or you can always have them coated</TD></TR></TABLE>
i got my header and IM coated inside and out by Calico Coatings, definately not flaking off!!
Re: (jdm420da6)
