b18c to c5?
Old Jun 18, 2006 | 04:56 AM
Chris_V-TEC's Avatar
Default b18c to c5?
hey jst purchased my new b81c , question i have is wht does it take to build it up tp a c5 spec imo itr piston's,rods,valve train, im, ecu? not sure if there's anything else i should know about any would be appreciated, cheers
Old Jun 18, 2006 | 11:08 AM
Dirtfall's Avatar
Default Re: b18c to c5? (Chris_V-TECH)
B18c5 doesnt have a gsr head they have a b16 with a factory p&p
Old Jun 19, 2006 | 10:41 AM
Death_to_Thieves's Avatar
If you are trying to build it to ITR specs, why didnt you just buy an ITR swap to begin with?
Old Jun 19, 2006 | 10:55 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: b18c to c5? (8000KReV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8000KReV &raquo;</TD></TR><TR><TD CLASS="quote">If you are trying to build it to ITR specs, why didnt you just buy an ITR swap to begin with? </TD></TR></TABLE>
Agreed, if you are going to spend money it should be to make it better.
Use the search, there are many examples of JDM GSRs which are better (more hp and torque) than Type-Rs.
You could begin by maybe building the head.
Old Jun 19, 2006 | 01:55 PM
Default Re: b18c to c5? (mar778c)
Reason i didnt buy an itr is because i stay in uk and is hard to come buy such an motor and i dont have the money to import anything, so havin to make do with wht i got, all my goals are really jst to reach the 200bhp mark or there abouts, but any help wouldbe of thanks.
Old Jun 19, 2006 | 04:12 PM
DC2SIR-G's Avatar
* B A N N E D *
dont buy ITR motor.. its all hype. its a waste of money.. its not that fast.. u can build a GSR and make it faster than a type R. i have a JDM GSR motor, all i did was upgraded ECU, skunk2 manifold, skunk2 stage1 cams, ITR tranny and the basic I,H,E.. now im walking all over type R'z all day.
Old Jun 19, 2006 | 07:33 PM
Ruben19's Avatar
Default Re: b18c to c5? (DC2SIR-G)
true!!
dont waste your money on a type r.
built a gsr and you can be faster for less money.
Thats what i did.
Old Jun 19, 2006 | 08:23 PM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2SIR-G &raquo;</TD></TR><TR><TD CLASS="quote">dont buy ITR motor.. its all hype. its a waste of money </TD></TR></TABLE>
I completely disagree, but what do I know?
Old Jun 19, 2006 | 08:42 PM
eskribble's Avatar
I'd build up from an ITR instead of a GSR motor. The B18c5 is a really bad *** motor compared to the B18c...I'm not saying the B18c is grabage! I'm saying the c5 is a much better start.
When you upgrade a B18c your basically upgrading to ITR standards and up. ......B18c5 &gt; B18c
JUST MY OPINION!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 20, 2006 | 06:14 AM
I got a honda's Avatar
Default Re: (eskribble)
ever considered LS/VTEC?? ls/vtec&gt;C1/C5
Old Jun 20, 2006 | 06:16 AM
UncleD's Avatar
Default Re: (iluvboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvboost &raquo;</TD></TR><TR><TD CLASS="quote"> ls/vtec&gt;C1/C5</TD></TR></TABLE>
87 &gt; 89
Old Jun 20, 2006 | 09:42 AM
Runnerdown's Avatar
Default Re: (clean rice)
his thread has some brilliant responses. type r and gsr are not very comparable anymore. all that is around these days is used motors. some are beat, others run great. generally the type r will be a bit stronger yes, but with a little bit of money and knowledge, each engine can be modified to run very strong. to the op, I suggest you invest a lot of time in researching.
Old Jun 20, 2006 | 10:47 AM
autox228's Avatar
Default Re: (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">his thread has some brilliant responses. type r and gsr are not very comparable anymore. all that is around these days is used motors. some are beat, others run great. generally the type r will be a bit stronger yes, but with a little bit of money and knowledge, each engine can be modified to run very strong. to the op, I suggest you invest a lot of time in researching. </TD></TR></TABLE>
yes i agree with runnerdown
JDMjoe86
Jul 23, 2007 05:41 AM
failed
Oct 18, 2005 09:56 AM
jowy
Apr 2, 2004 11:34 PM
BikeSpike
Jan 1, 2004 12:50 PM
. o 69 o .
Dec 1, 2002 11:47 AM
