Injectors on a B20
Re: Injectors on a B20 (shrums1la)
There are allot of different sized injecotrs out there so the options are pretty much endless. There is no best injector for your set up, you will not need an injector any bigger than a 440cc for sure. 310-370 should be fine along with a FPR, and a pump would be a good idea but not a must, you will also need something to control you fuel system with like hondata, crome etc. Otherwise you run the chance of runing really rich !! The main thing is that once you have all your parts and you get the car fired up get it to a dyno so you can tune it !
Sushi Buffet Champion
Re: Injectors on a B20 (silver vtec)
Definitely at least 290cc Prelude injectors. I was using 240cc stock injectors and the motor would bog from lack of fuel. 310cc would be ideal.
BoostedGSRBubble
11-15-2002 11:26 PM
