when doing a 96d16y7 swap with b18c1????
The starter does not fit. My GSR starter was finished when I tried to start it on Saturday and I pulled out my D16Y7 starter and the bolt holes don't match up. For the alternator, I was told that it was possible to put it on, but there would be a need to modify the brackets a bit. I don't know how though.
I'm not sure it the d16y7 alternator would have enough output for the GSR though.
Re: (e-kay)
would an si/sir alternator and starter work?
e-kay when you did your wiring what ecu did you use wire harness ect.???
to make the wiring easier could i use an si harness???
Thanks
Thanks
Re: (96lxb18csoon)
to make the wiring easier, use a 96-98 engine wiring harness. Some wires will have to be cut and extended. As for IAB wiring..........
You cant use the Si's(being that they are obdIIb)
Re: (b20_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20_EK »</TD></TR><TR><TD CLASS="quote">to make the wiring easier, use a 96-98 engine wiring harness. Some wires will have to be cut and extended. As for IAB wiring..........
I concur.
I concur.
odyody
10-06-2017 12:38 PM
sugafree
09-21-2015 03:05 PM
