98 5 lug swap on my Civic......need info from you ITR guys
OK, so I plan on getting a 5 lug swap for my EM1, and the swap I am looking at is from a 98 ITR. Now, my questions are as follows: this will have 36mm axles correct? Also, I can reuse my stock rear LCA's correct? What can I use from my current car and what will i need from the ITR swap?
Re: 98 5 lug swap on my Civic......need info from you ITR guys (jdm wannabe)
These are from a USDM ITR. Also, I have been told that I can use my SRR rear LCA's
Re: 98 5 lug swap on my Civic......need info from you ITR guys (1337 Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1337 Si »</TD></TR><TR><TD CLASS="quote">These are from a USDM ITR. Also, I have been told that I can use my SRR rear LCA's</TD></TR></TABLE>
as long as your SRR LCA's were made for an EM1 civic you can use them with the 5 lug setup.
try doing a "search".
This topic has been covered many times
Re: 98 5 lug swap on my Civic......need info from you ITR guys (808dc2)
Already had, and the reason I was asking is becasue I found a swap for 500 but it is gone now.
srt4mike
06-09-2009 08:30 PM
SPOONfdEK
08-15-2003 09:24 PM
