OBD1 b18a swap help
Re: OBD1 b18a swap help (integraracing91)
remove the resistor box
clip all the wires, strip the ends
connect all the wires together, preferrably w/ the oem style connector used on obd1 cars, or soldered together. Simply taping them together should work, but its pretty ghetto
Basically all you're doing is grounding the injectors.
Re: OBD1 b18a swap help (91IntegGS)
Correct either one of these will work.
On my first swap I went the ghetto route, ie.. electrical tape. This time around I'm using the obd1 connector.
shauniewalnuts
11-22-2004 07:15 PM
