b16a3 into an ek
Old May 20, 2004 | 03:05 PM
92eg6's Avatar
Default b16a3 into an ek
would i need all new mounts to fit a b16a3 into an ek
Old May 20, 2004 | 03:44 PM
deSigi's Avatar
If it's the same for all B-serie swaps, the only mount you could re-use would be you top tranny mount.
Old May 20, 2004 | 06:17 PM
DA6righthand's Avatar
Default Re: b16a3 into an ek (92eg6)
buy si mounts
Old May 28, 2004 | 05:37 PM
92eg6's Avatar
Default Re: b16a3 into an ek (nohondayet)
wouldnt the mounts fromm a b16a3 (delsol) fit on my ek chassis, i was thinking twice and to save $500 i was just gonna get an ls and buy mounts, but if i can use the b16a3 mounts then it would be better to get a b16
help please
Old May 29, 2004 | 08:23 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eg6 &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt the mounts fromm a b16a3 (delsol) fit on my ek chassis</TD></TR></TABLE>
No because the Del Sol is an EG chassis and the mounts are different. You need to use a 99-00 Si driver's side engine mount bracket and rear bracket. You can reuse your stock EK upper tranny mount, the front lower tranny mount and A/C bracket can be from the B16 Del Sol.
Del Sol on Steroids
Jun 4, 2007 09:15 PM
HB VTEC
Nov 24, 2006 07:40 AM
ek82
Dec 11, 2005 01:27 PM
endlessdv
Feb 26, 2005 07:53 AM
92eg6
Jun 8, 2004 08:41 AM
