b20 vtec pistons???
Old May 25, 2004 | 07:20 PM
boostinb20vtec's Avatar
Default b20 vtec pistons???
which company should i go with for my pistons?? I am going to be running a built sleeved b20b4 with a built gsr head and a turbo(probably t3/t4(not sure what size a/r and exhaust housings). I am looking to run around 9:1 compression. Also not sure of what size pistons to use. I wanna overbore the block, but can I go all the way to 87mm and still have a reliable motor, rev reasonably high(7500-9000rpms), and be able to handle boost without worrying about blowing up the motor.
Old May 26, 2004 | 09:44 AM
hellooo???? Anyone???
Old May 26, 2004 | 03:14 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (boostinb20vtec)
if you are boosting then do not overbore stick with 84mm 9:1 check out CP pistons or give us a ring
Old May 26, 2004 | 05:40 PM
why not overbore it...I am going to be sleeving it with dart mid sleeves???
Old May 27, 2004 | 05:19 AM
ttt
Old May 28, 2004 | 09:01 AM
ttmft!!!
Old May 28, 2004 | 11:39 AM
owen_the_soyboy's Avatar
Default Re: b20 vtec pistons??? (boostinb20vtec)
SEARCH
thru the FI forum, there are more/better opinions on this topic in there.
Old May 28, 2004 | 12:59 PM
thanks
traumatrix89
Feb 24, 2011 09:02 PM
jksmith
Dec 14, 2010 11:20 AM
uboostivtec
Feb 13, 2009 05:01 AM
boostinb20vtec
May 30, 2004 08:31 PM
boostinb20vtec
May 28, 2004 03:42 PM
