swap help, injector problem, 00 ek->h22a swap
ok so the 94 jdm h22a is installed in my 00 ek. we modified the ek harness with the correct h22 plugs. the car cranks over, sparks, fuel pump primes with fuel in the rail, but the injectors arent firing (no gas smell when cranking with open header) i verified that the resistor pack is getting 12v to the power wire on the pack, and all the wires from the pack are going to the injectors (removed this from the loom, un modified. Then on the other side of the injectors, the colored wires from the h22a harness matched up with the same colors on the civic harness. is there something we are missing? thanks.
also, its not pulling any CELs when cranking.
gunner6696
12-17-2005 10:07 AM
92TEGsrSC
02-29-2004 09:59 PM
