Hybrid is having troubles...Please look
stock jdm b18c in 92eg
alright, first thing, for the last two days, the car is havind difficulties starting up in the morning. it fires up for a second and shuts off. it sound like right before its about to idle, it dies. yesterday it took me about 5 tries to get it started. today about 10.
second, i cant seem to check the codes. i put a a paperclip into the green plug but nothing happens. am i checing the right one? its the green plug right below the glove compartment that hangs down right?
my SRS light is on. i swapped out steering columns over the weekend, put everything back together as it was. i missed one connector, and when i hooked it up, the light turned off. now its just constanly on. fuse? if so, which one is it?
thanks in advance.
thanks in advance.
Re: Hybrid is having troubles...Please look (3 3 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3 3 3 »</TD></TR><TR><TD CLASS="quote">stock jdm b18c in 92eg
alright, first thing, for the last two days, the car is havind difficulties starting up in the morning. it fires up for a second and shuts off. it sound like right before its about to idle, it dies. yesterday it took me about 5 tries to get it started. today about 10. </TD></TR></TABLE>
[B][Sounds alot like a bad fuel pump relay. Big grey box bolted right above you hood release. When the car tries to start and dies, smack it with a big wrench. If she fires right up, replace the relay/B]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">second, i cant seem to check the codes. i put a a paperclip into the green plug but nothing happens. am i checing the right one? its the green plug right below the glove compartment that hangs down right?</TD></TR></TABLE>
Going to be a blue 2wire plug. Will have a green rubber cover[/quote]
NZDelsoldude
01-25-2007 08:51 PM
