what mounts do i need???
Old May 25, 2004 | 03:33 PM
92eg6's Avatar
Default what mounts do i need???
if i want to swap a 98 LS engine in my 97 hatch, what mounts will i need, im assuming i need 00si mounts, but do i need all of them, the swap is coming with the mounts from the Ls
Old Jun 3, 2004 | 04:38 PM
phatcivic99's Avatar
Default Re: what mounts do i need??? (92eg6)
i do believe that you can use the stock civic mounts. i had a 00 civic hatch and i put a 98 ls in it and i used the same mounts.
Old Jun 5, 2004 | 04:26 PM
CrVtec122's Avatar
All B series motors and trannys bolt right into any 96-00 civic hacthback, coupe, or 4 door. And same goes for the Integras between the years of 90 ,I believe, and 01. And I'm pretty sure the same thing goes for all eg's.
Old Jun 8, 2004 | 07:33 AM
carlton585's Avatar
Default Re: (CrVtec122)
and 92-95 do the same also.
Old Jun 8, 2004 | 08:41 AM
VTECVillain's Avatar
For all 96-00 EK Civic's:
* 99-00 Si driver's side mount bracket then reuse your stock EK rubber mount.
* 99-00 Si rear mount bracket then reuse your stock EK rubber mount.
* Stock EK upper tranny mount.
* 99-00 Si or 94-01 Integra lower front tranny dampening bracket then reuse your stock EK rubber end mount.
* Del Sol VTEC A/C bracket (to retain A/C) or any 94+ B-series bracket if being used only for the dampening mount then reuse your stock EK rubber end mount.
SeVeNisOnE
18
May 21, 2008 03:02 PM
HB VTEC
Nov 24, 2006 07:40 AM
dc2drifterx
May 9, 2005 12:15 PM
ApexiChild
Nov 29, 2004 02:13 PM
92eg6
May 29, 2004 08:23 AM
