shift linkage help
Old May 19, 2004 | 05:28 PM
jaydmej1's Avatar
Default shift linkage help
willl a gsr shift linkage fit on an ls tranny that is being swaped into a b18b del sol?
Old May 19, 2004 | 06:49 PM
96lxb18csoon's Avatar
Default Re: shift linkage help (wallasol)
any b series shift linkages will work
Old May 20, 2004 | 08:30 AM
b18cx's Avatar
Default Re: shift linkage help (96lxb18csoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96lxb18csoon &raquo;</TD></TR><TR><TD CLASS="quote">any b series shift linkages will work </TD></TR></TABLE>
WRONG!!!! 94 Up teg shift linkage is the same. Del Sol shift linkage is different than everything else out there. B-seires and D-series Del Sol shift likage is SPECIFIC to the Del Sol.
If you doing a swap in a Del Sol that origionally had a D-series motor in it and you are now putting a B-Series motor in it, you MUST use the B-series DEL SOL shift linkage. First hand experience here, no guessing, all fact.
da_driver_15
Dec 28, 2010 05:42 PM
monsterb18b
Aug 11, 2008 06:11 AM
turbodelsol3
Mar 9, 2007 11:57 PM
SOLvtec
Oct 27, 2006 09:30 AM
AzntaggeR
Dec 23, 2003 09:34 PM
