Strange Vtec problem
Old May 27, 2004 | 10:47 PM
deSigi's Avatar
Default Strange Vtec problem
I searched for similar symptoms, but found nothing. I swapped a 98 B18C1 into my 96 DX coupe. Vtec kicks in for a certain amount of time and then without notice, stops working. I get a complete rpm cutoff at 5000 rpm and I get a CEL code 22 (VTEC pressure switch). If I restart the car either at a stop light or whatever, I'll be able to hit Vtec a couple of times again (even with the check engine light on) and then it does the exact same thing as before. My rpm cuts off at 5000 rpm. It basically bogs at that speed. It does the exact same thing that any engine does when it has a rpm or speed cut off. When I hit Vtec though, I can redline it. But once I get the rpm cutoff at 5000, I have to turn the engine off and then back on to be able to hit Vtec once more.
Anyone have similar symptoms to this or might know what I can do to try and fix this odd problem? Any help would be appreciated.
Old May 28, 2004 | 06:19 AM
deSigi's Avatar
bump
Old May 28, 2004 | 10:40 AM
biggs2.3's Avatar
now i'm no expert but it sounds like you may need to change your vtec pressue switch
Old May 28, 2004 | 10:44 AM
deSigi's Avatar
Default Re: (biggs2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggs2.2 &raquo;</TD></TR><TR><TD CLASS="quote">now i'm no expert but it sounds like you may need to change your vtec pressue switch</TD></TR></TABLE>
Really? Even if it works a bit once the car has been restarted?
Old May 28, 2004 | 11:30 AM
biggs2.3's Avatar
*Shakes magic 8-ball*
All signs point to yes
Old May 28, 2004 | 01:26 PM
h22Hatchy's Avatar
Default Re: Strange Vtec problem (e-kay)
check and make sure you have no loose wiring. Make sure the pins in the ecu are touching and nice and tight.
Old May 28, 2004 | 01:32 PM
deSigi's Avatar
Default Re: Strange Vtec problem (h22Hatchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22Hatchy &raquo;</TD></TR><TR><TD CLASS="quote">check and make sure you have no loose wiring. Make sure the pins in the ecu are touching and nice and tight.</TD></TR></TABLE>
That reminds me, when I was adding the wires for the Vtec pressure switch and IAB, I had run out of extra pins that would go into the ECU clip. I bought some at a scrapyard, but they were from an OBD1 clip not OBD2. I only noticed it once I got home. I was able to fit them in, but it required a bit of crimping to get them to fit. Could this be the problem? Maybe the OBD1 pins aren't touching the ecu all the time. Would I get these kinds of symptoms if it was the case?
I bought some OBD2 pins finally, but haven't had a chance to replace them.
Let me know what you think about this.
Old May 29, 2004 | 05:37 PM
Danethomp's Avatar
i had this problem. i had the wrong size pins and they would fall out when vtec engaged. altho now i got the right pins but after vtec engages i'm getting a code 22 and then no more vtec . the vtec oil pressure sensor is good though. i have no clue.
Old May 29, 2004 | 08:34 PM
deSigi's Avatar
I just topped the oil off and it still does it. I'll change my pins tomorrow and I'll see what happens. 90g2ls I'll keep you posted.
Old Jun 3, 2004 | 05:08 PM
deSigi's Avatar
Fixed the problem. It turns out it wasn't the Vtec pressure switch that had the OBD1 pin, but the knock sensor. Changed it and now no rev limit and Vtec engages w/o a problem.
Thanks guys for all your support!
Modified by e-kay at 9:12 AM 6/4/2004
Old Jul 10, 2004 | 11:08 AM
civicHBphtride's Avatar
Default Re: (EKsleeper)
I am having this problem i hope this works thanks to the search i found some help! 1
Old Jul 13, 2004 | 02:03 PM
ls_vtec_crx's Avatar
ok so did you change your knock sensor or did you change the pin for the knock sensor?
Old Jul 13, 2004 | 02:20 PM
deSigi's Avatar
Just the pin. It wasn't in full contact with the ECU.
Old Jul 13, 2004 | 04:11 PM
crxirex's Avatar
Default Re: (deSigi)
Isn't a code 22 and electrical problem anyways?
Old Jul 13, 2004 | 07:55 PM
i thought it was the oil pressure switch, mines was throwing code 22 and its because the oil line was too small and the head wasnt getting enough oil and the vtec wasnt enguaging
HondacivDX
Feb 19, 2012 06:52 PM
fryman
Sep 28, 2008 02:32 PM
MADMAXX
Jul 21, 2005 09:43 AM
