Oxygen Sensor (O2) The Same?
Old May 20, 2004 | 04:59 PM
JohnnieChimpo's Avatar
Default Oxygen Sensor (O2) The Same?
I need an O2 for my swap. I priced a new one and they are $200+.
I had a thought that I would pick up one at the junkyard.
They asked me what engine. I told them GSR.
They told me they didn't have any.
Wouldn't they all be the same? Even off of a Civic as long as its 4 wire?
Unless you guys know where to get a new one for less.
I tried searching but O2 is too small to work on this search engine.
Old May 21, 2004 | 05:08 AM
CHEETAH's Avatar
Default Re: Oxygen Sensor (O2) The Same? (JohnnieChimpo)
yes any 4 wire honda will work, even OBD2 rear o2 sensor (wires are longer thats all)
greg
Old May 23, 2004 | 10:45 AM
JDM EJ1 95's Avatar
I have a used four wire sensor that works fine if you want it IM me.
Old May 25, 2004 | 05:11 AM
CRITTERMATT's Avatar
Not all 4 wire O2 sensors are the same. When I did my B16 swap into my 99 EX i tried to use my EX O2 sensor but the plug is different. I do beleive that all Integra's use the same primary O2 sensor as does the 99-2000 si. Check denso's website and it gives the part numbers of the O2 sensors.
__________________________________________________ __________________
Taken from Denso's website
For 2000 Acura Integra
GS L4/1.8 -- Front 234-4011 234-4209
GS L4/1.8 -- Rear 234-4659 234-4209
GSR L4/1.8 -- Front 234-4011 234-4209
GSR L4/1.8 -- Rear 234-4659 234-4209
LS L4/1.8 -- Front 234-4011 234-4209
LS L4/1.8 -- Rear 234-4659 234-4209
TYPE-R L4/1.8 -- Front 234-4011 234-4209
Hope this helps
1993eghatch
Sep 24, 2010 05:52 PM
Clipsed
May 9, 2008 12:51 AM
mugenhatch92
Aug 21, 2004 09:25 AM
boostinb18
Jul 26, 2002 01:31 PM
radiac
Jul 5, 2001 08:45 PM
