99 dx hatch B16 SirII ?
I have done some searching and I am more or less confused about obd codes.
Is it a bad idea to put a 2nd gen b16 (sirII) into a 99 dx hatch?
OBD1 motor and an OBD2 car.
Should I use an adapter ? If so which one? Is it considering OBD1 to OBD2 or OBD2 to OBD1?
Any added parts I would need for the swap?
What wiring harness? would a stock ex work?
Any good reading or just answers would be great.
Re: 99 dx hatch B16 SirII ? (99hatchdx01)
You will need an OBD2b to OBD1 ECU jumper harness, probably among other things. I have never performed this swap myself but, I know that you will either need the jumper harness or say a 99-00 Si ECU.
theslugbug
10-29-2003 12:15 AM
93VAhatch
03-05-2003 09:04 PM
