HELP! is a b18/b20 hybrid build possible?
HELP! is a b18c5/b20 hybrid build possible?
*NOTE* THIS IS FOR A B18C5 HEAD! ive seen info on a b18c1 head on a b20 block but not a b18c5. ok, im looking on ebay and i found an ITR and in the description said the engine was a b18c5 head on a b20 block. ive seen plenty of stuff about b16 heads on b20 blocks, so i wanted to see if this an actual possible swap, and if so what kind of power would it make, how reliable would it be, do i need to worry about revving higher without having to worry about the crank killing itself (dont know much b20 rev limits), etc...? if this has been answered in another post that i couldnt find, could you please let me know? thanks in advance.
Modified by XiOus271 at 6:34 PM 2/18/2006
Modified by XiOus271 at 6:37 PM 2/18/2006
ok, so im sure that the swap does work, so i think i should change my question to how reliable is it, what kind of power does it make, and how high would you rev it. if anyone can help me with this it would be greatly appreciated!
