99 civic ex brakes on my 94 del sol?
I have a wrecked 99 civic ex, What would I need to do to put the front rotors on my 1994 Del sol?
Re: 99 civic ex brakes on my 94 del sol? (feathers321)
Just the rotors, or the entire brake assembly? Either way - easiest way is to disconnect the entire steering knuckle and bolt it to your Del Sol. Its only 4 bolts and it comes off...
Re: 99 civic ex brakes on my 94 del sol? (EK-Chris)
I was going to try to use just the rotors, maybe the caliper bracket. The civic has larger rotors than my Sol. Wouldn't I run into problems if I swapped the whole brake assembly since the Civic has ABS?
Just because it has ABS doesnt mean you have to use it. Its just a sensor, my Integra steering knuckles had it, its just not being used (ABS). Its a lot easier and faster to swap the entire steering knuckle.
Look at my setup:
1) 94 Integra knuckles
2) Type R Calipers, w/ stock Pads *Calipers were cut 4 mm for clearance
3) 11.1 Fastbrakes Brembo slotted/drilled rotors
All OEM honda parts, you just have to know the right combinations...
Look at my setup:
delsolnewkid
03-13-2006 07:20 AM
dnbruut
10
10-11-2005 10:10 AM
duh blacksheep
12
04-26-2005 07:53 AM
