hybrid problems
Old Feb 19, 2006 | 10:02 PM
SupraRXZ's Avatar
Default hybrid problems
d16z6 in a 90 civic hatch converted obd1
I try starting my car rite after i dropped it in...everything pluged in rite....and when i start it i hear a noise that sounds like air escaping or moving or sumthing but it wont crank, my tach goes up and down and i hear like a hissing noise
I think my starter is bad but do you guys have any other suggestions?
when i first started it it cranked a lil bit but wont start and then we tried a couple times and i think my engine froze so we manually turned the crank to un freeze it and now its making that weird noise and wont crank at all.
Old Feb 19, 2006 | 10:43 PM
SupraRXZ's Avatar
Default Re: hybrid problems (SupraRXZ)
bump
Old Feb 19, 2006 | 11:28 PM
b16_sol_707's Avatar
if the starter is continuously trying to turn the motor while you hold the key to start, the starter is good. I would have the ECU checked or the main Relay. I had a similar problem on my brother's CRX.
Old Feb 20, 2006 | 12:07 AM
SupraRXZ's Avatar
Default Re: hybrid problems (feathers321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by feathers321 &raquo;</TD></TR><TR><TD CLASS="quote">if the starter is continuously trying to turn the motor while you hold the key to start, the starter is good. I would have the ECU checked or the main Relay. I had a similar problem on my brother's CRX.</TD></TR></TABLE>
How do i check the ECU and main relay? i checked all the fuses and there all fine, and as for the starter, it doesnt click or anything , i hear a hissing of air or something, and we took the starter out and put the positive and negitive battery on it and it doesnt even pop out, and we put a screw driver between it to see if it comes out, but all it does it spark, and after like the 5th time it came out a little bit but didnt move it was like stuck
Old Feb 20, 2006 | 07:27 AM
SupraRXZ's Avatar
bump
Old Feb 20, 2006 | 08:34 AM
SupraRXZ's Avatar
checked starter....its working....now what?
Old Feb 20, 2006 | 01:11 PM
Default Re: (SupraRXZ)
The easiest way to see if the ECU is good is to put it in a car that has the same ECU that you know is good.
Where is the hissing noise coming from? I would try to track it down to a specific part.
BlueVxIDelSlo
Apr 6, 2011 06:29 PM
mikej94civex
Apr 28, 2010 07:49 PM
only1gcue
Jun 24, 2006 07:02 AM
SupraRXZ
13
Feb 21, 2006 08:04 AM
SupraRXZ
Feb 20, 2006 08:35 AM
