help please d15b swap
Old Feb 11, 2006 | 08:32 PM
dizzyek's Avatar
Default help please d15b swap
Okay I just put a obd1 d15b into my 96 hatch. We used my stock dx harness and modified all of the wiring to get it to work. The engine turns over no problem and idles perfectly. But it only wants to rev to like 2000 rpms. My mechanic sprayed some airfilter cleaner into the intake manifold while reving it and it reved up like a champ. Timming is good, plugs are good, injectors are good. It judt doesnt want to rev and missis alot when you try too. I am using the original p08 ecu with a jumper harness. But we are using my stock dx oxygen sensor which is 4 wires. the original motor used a 1 wire o2 sensor. Could this be the problem? If the p08 was programed to read a 1 wire o2 sensor could the stock dx o2 sensor be throwing off the air ful mixture? need some advice asap thanx.
Old Feb 11, 2006 | 08:36 PM
TheNosR's Avatar
Default Re: help please d15b swap (dizzyek)
u suck you did somethings wrong
Old Feb 11, 2006 | 08:37 PM
TheNosR's Avatar
Default Re: help please d15b swap (h22special)
were u nossing it
Old Feb 11, 2006 | 08:57 PM
dizzyek's Avatar
anyone with some advice please.
-=ZAK=-
May 3, 2009 04:43 PM
hondamonda
Jan 24, 2008 05:18 PM
dizzyek
Feb 19, 2006 07:02 AM
Equilibrium
Nov 2, 2004 01:33 PM
TwoK4drSi
Mar 1, 2004 09:17 PM
