Engine Swap HELP NEEDED
Old Feb 10, 2006 | 05:04 AM
a2K00's Avatar
Default Engine Swap HELP NEEDED
I have a 1993 1.5 Civic LSI (1.5DB2) (UKDM) and i have bort a 1995 1.6 VTEC LSI (VTEC 1.6Z6,I Think)(UKDM) engine for a transplant, it comes with the required gearbox, wiring loom and ECU, i need to know if the engine mountings are the same and the gear linkages and driveshafts are the same. will the engine directly swap for my non VTEC 1.5?? Will i need new drivshafts or radiator? Please advise because my 105BHP is shitty and i really need to get my 130BHP 1.6 fitted. PLEASE HELP
Modified by a2K00 at 2:19 PM 2/10/2006
Old Feb 11, 2006 | 08:20 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Engine Swap HELP NEEDED (a2K00)
Everything should be the same. Not sure if the 93 LSI has VTEC wired in the harness so you may have to run wires for the pressure switch and solenoid/solenoid ground.
Walker Hall
Honda Civic (2001 - 2005)
Dec 1, 2016 01:44 PM
VadimScream
May 2, 2015 06:57 PM
primolee
Sep 12, 2013 12:55 AM
