tps??
Old Feb 13, 2006 | 07:25 PM
:Andrew's Avatar
Default tps??
Ok i have a quick question.I have a 97 civic dx with a b18c swap, well not too long ago it threw a code PO122 (throttle position sensor circuit low input).So my first thought was to replace the tps, so i removed the tb and hacksawed into the rivets on the tps making them flathead screws.I then bought a new tps and replaced everything, but when i turned the car on the(cel) came back on and the problem remained.It idles hard between 3000rpms and about 5000rpms, so im thinking now the wiring may be bad, or maybe it's grounding out somewhere can anyone lead me in the right direction to fixing this.
thanks
Old Feb 14, 2006 | 06:13 AM
JasonST's Avatar
Default Re: tps?? (gsrdx)
Did you calibrate the tps sensor before you put it in?
Old Feb 15, 2006 | 10:07 AM
Braco11's Avatar
Default Re: tps?? (JasonST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">Did you calibrate the tps sensor before you put it in?</TD></TR></TABLE>
yeah, you need to do that. you can't just screw a new one in and be on your way. at idle, need the volt reading to be ~.45V and ~5.0V at WOT.
quick explanation of what to do: put on the tps (leaving the screws loose so you can adjust the tps like you do your dizzy), probe the middle wire, turn the key to the on position (engine should still be off), adjust tps til readings are .45V, screw tps on tight in that position, clear codes, and you should be set.
valentine97
Jan 14, 2008 12:44 PM
ek_chris
10
Sep 12, 2006 09:57 PM
ScottEK
Jun 12, 2006 06:02 AM
MsMaureen
14
Jan 24, 2005 05:32 PM
wu tang
Jul 1, 2003 08:27 PM
