k20a2 head swap onto a k24a4?
the k20a2 comes stock on the rsx-s and the k24a4 comes stock on 7th gen 4cyl accords. I'm only really switching the heads? How much did the parts cost? Anything special, trials, tribulations?
Thanks
Thanks
Re: k20a2 head swap onto a k24a4? (msedacca)
I'll be doing the same up other than using a K24a4 off an Element. You'll need to change out the pistons or the valves will tap. I'm changing mine to a TSX pistons and rods.
Re: k20a2 head swap onto a k24a4? (k25a2kid)
theres also a how-to article on sportcompactcarweb.com with all the basics, plus I'd be having a shop do it for me because I am not mechanically inclined. Just curious if anyone had done it before, and since I plan on going all-motor no real boost for awhile, I wouldn't need to worry about getting aftermarket internals.
Edit: After talking with a number of people on the k20a.org site, I discovered that if you're doing a k24a4 swap on the accord, it MUST be a manual and needs the kpro reflash in order to run correctly. So I gotta do the manny swap first before I get going with this.
Modified by msedacca at 7:18 PM 2/16/2006
