00 Si B16 into a EJ1 swap questions mounts, wiring.
Okay, I have 94 EJ1 and I have a 00 Si B16A2. I want to combine the two! I think I have the wiring harness figured out. I have 98 Spec ITR wiring harness, this is the correct harness to hook into the EJ1 wiring correct?
Now mounts. I have 98 spec ITR engine mounts, and brackets. Between the EJ1 stuff, and the ITR stuff, do I have all the brackets/mounts for the engine swap? I was reading somewhere, I might need a EM1 tranny torque mount....
Thanks in advance, and I did try and search, but I can not find the info, it might be there, but I cant seem to find it!
Here is another question. I want to run a Hondata s200. But my dyno guy is about 5 hours away. The B16 is running CTR pistons and ITR cames. For the mean time should I use the unchipped p28 or the Sis(p72 i beleive)?
N1 Andy
06-12-2004 08:05 PM
chipper
10
06-05-2002 07:43 PM
