swap?
Old Feb 10, 2006 | 10:29 AM
EJ8 GSR-T's Avatar
Default swap?
i am trying to find all the info on a swap from a d16y8 to a b16a, i want to do it myself but i dont have the welding tools, and such so i want to see if its even do-able
Old Feb 10, 2006 | 11:00 AM
IHateJDM's Avatar
Default Re: swap? (userdead626)
no welding required for this swap.
Old Feb 10, 2006 | 11:02 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">no welding required for this swap. </TD></TR></TABLE>
x2
Here's a couple threads you should check out
https://honda-tech.com/zerothread?id=878010
https://honda-tech.com/zerothread?id=983454
Old Feb 10, 2006 | 01:18 PM
b16_DIM's Avatar
I just swapped my d16y7 for a b16a, It was pretty much bolt in, I decided to do my own wire harness, that was a bit of a chore. All the parts pretty much bolt in though...Oh if you are keeping your ac you may need to get some lines crimped. I choose to have new fuel lines and slave cylinder lines crimped as well. I ended up having my ECU chipped because they gave me an automatic ecu for a manual swap (don't quite know how that happened ) but the chipping was only $100 and it came with the added bonus of no speed govenor, rev limiter, etc...As far as tools you really won't need much more than a good metric socket set, deep set socket set, screwdrivers, solder gun (elec tape, solder, flux etc..). The specialty tools I used were a ball joint seperator ($10 at a auto parts store) and a really big socket i borrowed from a friend to take the nut off the axle. send me a pm if you have any problems
ThaBread
30
May 11, 2013 01:25 PM
BLUIZE256
Feb 2, 2007 02:50 PM
Felliph3
20
Oct 18, 2006 08:52 AM
tallyturbo
Jan 3, 2006 03:19 PM
mugenwannabe
18
Apr 16, 2003 06:06 PM
