radiator issues with b18c in ek coupe
Old 02-25-2006, 02:12 AM
ricky05's Avatar
Default radiator issues with b18c in ek coupe
ok so i want to buy a fluidyne or koyo racing radiator for my 98 civic which will be getting a b18c drop in soon...what about the hoses? do the stock hoses reach to the radiator from a b18 or do i need to order some special ones? current motor is a d16y5 (non vtec) if that helps
thanks!
Ricky
Old 02-25-2006, 04:53 AM
RTFM
v4lu3s's Avatar
if you buy an integra radiator it will be harder to even fit it in the chassis. if you buy the civic oversize radiator it should ft like stock with more thickness only.
Old 02-25-2006, 12:10 PM
joe_bocc's Avatar
Default Re: (v4lu3s)
I do believe you will need the 99-00 Si hoses. Theres also an issue with the radiator inlet/outlet sizes as well. I'm not sure but I think I remember that being the case and it would make sense.
Can anyone confirm?
Old 02-26-2006, 12:26 AM
ricky05's Avatar
Default Re: (joe_bocc)
well what CAN i do so that i can retain A/C? i need AC when vegas summers come in...lol
what radiator will work in a 98 civic with a 2000 gsr engine? what hoses do i need..etc.. thanks
Old 02-26-2006, 06:23 AM
RTFM
v4lu3s's Avatar
the stock radiator works great.
Old 02-26-2006, 10:56 AM
ricky05's Avatar
stock civic...or stock integra..
and the stock ek hoses fit on b18? thats what i dont understand
Old 02-26-2006, 01:51 PM
RTFM
v4lu3s's Avatar
the stock civic radiator works perfectly fine. hell i used a stock civic radiator with an h22a for several years til i turboed and went woth a thicker civic one.
Old 02-26-2006, 05:38 PM
ricky05's Avatar
what about the hoses? and can u keep a/c? what about an aftermarket radiator..which ones support keeping a/c. i would rather have an aftermarket one
Old 02-26-2006, 05:43 PM
RTFM
v4lu3s's Avatar
if you absolutely have to waste money on an aftermarket one you buy a civic aftermarket one. do you know what the difference between a civic and integra radiator is?
Old 02-26-2006, 10:04 PM
ricky05's Avatar
no i dont.
Jdmintegr
05-12-2011 05:26 PM
NoLeftTurn
12-08-2005 05:47 AM
monicle
06-13-2003 06:14 AM
DarkCyde SI
01-27-2003 03:11 PM
Quick Reply: radiator issues with b18c in ek coupe
