FLYWHEEL RESURFACE????
Old Feb 8, 2006 | 07:02 PM
b18c inside's Avatar
Default FLYWHEEL RESURFACE????
Do you have to have the flywheel resurfaced when replacing the clutch? Just a simple answer will be fine.
Old Feb 9, 2006 | 03:13 PM
blackb18c1eg's Avatar
Default Re: FLYWHEEL RESURFACE???? (B18C inside)
You should! Its not too expensive and most machine shops will do it
Old Feb 9, 2006 | 06:25 PM
jmcool's Avatar
definetly do it
Old Feb 9, 2006 | 07:58 PM
SteveoBA8's Avatar
Default Re: FLYWHEEL RESURFACE???? (jmcool)
Do it, my dumbass didnt before i put my engine/tranny in and now i get to pull the tranny out this spring break cuz clutch chatter is fukin annoying(yes my mounts are tight) Replace the rear main seal while your in there
sebTeggy
Sep 21, 2011 04:24 AM
numotive
Sep 21, 2005 04:37 PM
blaster834
Aug 14, 2004 02:34 PM
StolenTeg
Aug 3, 2004 10:33 PM
Rywire
Apr 20, 2004 03:55 PM
