well
Old Feb 8, 2006 | 10:37 AM
91-lsvtecsi's Avatar
Default well
well here is my story, i bought a obd0-1 ecu jumper harness from evasive sport. i also bought a vafc froma fellow h-ter, i wired up the vafc to the ecu jumper harness and wow we had power so the next day i wanted to finsh up the wiring(you know vtec sol. press, ect...........) so i had everything wired up and i turned the key to ACC and i heard my IACV Humming. and i checked the vafc and the lights in the unit where very dim, i disconnected the iacv and vafc lights were off. so i lefted it like that til the next day . woke up the next day and once again check all the wiring and everything looks good. now the problem today is i connect the obd1 ecu and i get a CEL and no power to the vafc or any plugs to the engine bay. i tried the obd0 ecu and CEL is on wit no code blinking!!!! also i checked the ecu fuse looks good. Is there anywhere i should be lookin into??? also the car is 91 si wit lsvtec motor PLEASE PLEASE HELP
Old Feb 8, 2006 | 11:14 AM
Default Re: well (88lscrxsi)
bump
Old Feb 9, 2006 | 02:48 PM
nevermind it was the alternator solenoid FUSE!!!
USDM EG
May 31, 2006 08:38 AM
TurboBumblBee
Nov 8, 2003 10:44 AM
tc
Sep 11, 2003 11:38 AM
thehondaguru
Aug 12, 2003 08:54 AM
Blazeone
May 21, 2003 07:10 AM
