obd0-obd2 injector
Old Feb 9, 2006 | 04:58 PM
shuttle xer's Avatar
Default obd0-obd2 injector
i swapped a obd2b b20vtec into a 91 dx. Now it barely starts and does not hold idle. the **** misfires like a mother.
it has to be fuel or spark. i replaced the rotor, cap, wires, ignition coil and plugs. still no dice.
i noticed that on the injectors there is a (+) positive symbol on the side of it. The side with that symbol is where the ground wire goes (colored wires.blue,red,yellow,brown). is the power supposed to be running to those wires?
that might be one of the reasons why this thing doesnt really start.
Old Feb 9, 2006 | 09:39 PM
Default Re: obd0-obd2 injector (shuttle xer)
blahhh
Old Feb 14, 2006 | 11:14 PM
theinfamouskonrad's Avatar
are you running a resistor box? If your using obd2 injectors they are saturated and you run no resistor box.
and your running obd0 still or did you convert? what dizzy are you using?
also, double check your dpfi-mpfi wiring.
crxsi814
Jan 8, 2011 01:50 PM
crxcess
10
May 26, 2006 09:56 AM
shuttle xer
Feb 9, 2006 09:38 PM
pa2play
Jun 28, 2004 04:26 AM
fearless_dsm
Mar 10, 2004 04:24 PM
