no code for iat and map sensor
Old Feb 8, 2006 | 08:29 AM
whitelightning's Avatar
Default no code for iat and map sensor
i've got an obdII to obdI b18c in an ek...
i'm using the kenji harness and running the obdI p72. when i unplug the two sensors, i am not getting any codes, any ideas? i should be getting a CEL correct?
Old Feb 8, 2006 | 10:11 AM
spoink's Avatar
Default Re: no code for iat and map sensor (whitelightning)
Have you driven it around with them unplugged or just sitting at idle?
Old Feb 8, 2006 | 11:06 AM
IHateJDM's Avatar
Default Re: no code for iat and map sensor (spoink)
your map may not throw a code right away, drive on it and I bet it'll show up. My ecu doesn't read my iat either. Its a chipped p28, but iat was not disabled. weird.
Old Feb 8, 2006 | 01:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoink &raquo;</TD></TR><TR><TD CLASS="quote">Have you driven it around with them unplugged or just sitting at idle?</TD></TR></TABLE>
sitting at idle yes, but have not driven it around, i may try this later...will this hurt the performance? if the plugs aren't properly wired? the car has been like this since 1997ish...
i'll unplug the map as well. see what happens...
speedooo
11
Jul 24, 2008 09:27 AM
Kyle244R948
Sep 24, 2004 03:26 PM
Race Egr
Apr 5, 2004 10:32 PM
Race Egr
Apr 4, 2004 08:48 AM
