b18c1 idle problem in 97 ek
Old Jun 13, 2007 | 10:01 PM
mr 636's Avatar
Default b18c1 idle problem in 97 ek
hey all, my gsr is idling at 2000+ at random times. this only seems to happen if i let it ride in gear and after i step on the clutch. it'll go back down sometimes after i rev it a little or come to a complete stop. i checked for vacuum leaks, but i don't see any and i cleaned the iacv 10 times. what could be the problem? please help i need to state ref this crap soon!
thanks!
Old Jun 14, 2007 | 04:00 PM
mr 636's Avatar
Old Jun 15, 2007 | 11:21 PM
mr 636's Avatar
man no one likes to reply to any of my threads!
i searched and found nothing relevant that helped.
Old Jun 16, 2007 | 02:00 PM
dbiker207's Avatar
Default Re: (mr 636)
check the fit valve below the throttle body. there is a sheet metal cap on one end held in with 2 small bolts. the other end has hoses. take the sheet metal end off and you will see a doughnut shaped white plastic piece with 2 slots in it. tighten that down, if it is loose it will cause a surging idle that gets worse as gets looser.
Old Jun 16, 2007 | 04:03 PM
B16Civic93's Avatar
Default Re: (dbiker207)
What he said!
ek_ct
Oct 22, 2014 06:33 PM
ek.troy
12
Feb 13, 2012 03:45 PM
dragonvoi
11
Sep 3, 2011 01:31 PM
Prod
Sep 29, 2004 03:50 PM
eak_degenr8
Feb 18, 2004 12:23 PM
