92-95 w/ k20a2 swap - What full size aluminum radiator?
Looking to go with a full size aluminum radiator.
I've heard EP3 and I hear you can go with an RSX.
Car is a 95 VX and the motor is a k20a2 (2003).
Thanks for any advice
Example:
Example:
Re: 92-95 w/ k20a2 swap - What full size aluminum radiator? (Mr.OB*GYN_Rhett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.OB*GYN_Rhett »</TD></TR><TR><TD CLASS="quote">ep3/rsx </TD></TR></TABLE>
Now I am reading the radiator is close to the intake manifold which will make the IM run hot. Also, a half size allows air in through the front bumper / open space to cool the motor. Looks like it will be half size dual core aluminum
Thanks for the info!
Re: 92-95 w/ k20a2 swap - What full size aluminum radiator? (Hybrid93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch »</TD></TR><TR><TD CLASS="quote">Now I am reading the radiator is close to the intake manifold which will make the IM run hot. Also, a half size allows air in through the front bumper / open space to cool the motor. </TD></TR></TABLE>
You gotta think the EP and the RSX use a full radiator along with a condenser in front of it and run just fine. The extra coolant cooling capacity of the full radiator will help alot more than air running over the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">
You gotta think the EP and the RSX use a full radiator along with a condenser in front of it and run just fine. The extra coolant cooling capacity of the full radiator will help alot more than air running over the motor. </TD></TR></TABLE>
True, but how close is the radiator in those 2 versus an EG?
Re: (Hybrid93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch »</TD></TR><TR><TD CLASS="quote">True, but how close is the radiator in those 2 versus an EG? </TD></TR></TABLE>
Doesn't matter. Once warm the intake will be much hotter than the radiator will get no matter the location. Go drive a B or D series Civic and feel the fins and the intake. The intake is over 150 degrees and the surface temp on the fins is around 120 or less. The radiator radiates the heat from the coolant right away and if it's cooler than the intake it won't cause any increase in temps on the intake. If you still had any concerns you could always use a hondata gasket and keep the temps down.
Bsmith1010
27
05-15-2019 07:23 AM
yeegsr
15
11-27-2004 08:29 PM
