B18c1 into 93 VX hunchback
Old 06-03-2007, 11:38 AM
Junked99Si's Avatar
Default B18c1 into 93 VX hunchback
I have a 93 VX hatchback and I am going to swap a B18c1 OBD1. The car has no wire harness in it right now. Any sugesstion or any better way to wire it up??I have the harness for the motor but the cars harness is on the groun next to it. Also I don't have a ECU... any other suggesstions?? What kind to use? Thanks
Old 06-03-2007, 05:03 PM
jdmboyef9's Avatar
Your stock VX harness should work perfect. All of the VTEC wires are already there. You may have some extra wire left over. You also have to wire up the butterfly valve unless you go with the Sk2 manifold....
MShonda
12-15-2010 11:57 AM
ivicr
10-08-2009 11:18 AM
dpine
06-01-2006 08:26 AM
jdmteg01
11
08-23-2004 09:36 AM
Quick Reply: B18c1 into 93 VX hunchback
