What final drive on your H2B ??
King of the One Liners
Stockpiling all my parts for my upcoming H2B swap.
What final drives is everyone using in their swaps. Yes i will be beating the ish out of it at the track
Im using a b16 trans and i figure i might as well swap it out while i have the trans on the workbench.
thanks
Re: What final drive on your H2B ?? (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR »</TD></TR><TR><TD CLASS="quote">Yes i will be beating the ish out of it at the track </TD></TR></TABLE>
go with something very aggressive and match the slick size accordingly.
I'm really 2slow
Re: What final drive on your H2B ?? (2point2)
it all depends on the setup really. high hp cars use bigger tires and bigger final drives. If it will be street driven I would stick with a 4.4 final drive and 22-23" slicks.
You should check out http://www.mfactoryhk.com. They have a variety of final drives at very competitive prices. I'm using an MFactory 4.928 Pro Series final drive on 24.5" slicks @ about 6psi, drag spool, twin disc clutch w/o preloading and it seems to be holding up after countless amounts of passes. You can also PM them. HT screen name: mfactory. peace!
98_1LE
08-05-2005 06:46 PM
