whats the difference vs ekk1/2 mounts
Re: whats the difference vs ekk1/2 mounts (dropped like its hott)
Hasport would like to announce the release of the new EKK2 mount kit. This kit is designed to be use with the EG crossmember, steering rack and lower control arm. This allows the engine to be mounted rearward another 2 inches and up about an inch. This ideal for drag racing as it straightens the axles and road racing becuase it moves engine weight rearwards.
The kit has two sets of mounting holes so that the engine can be mounted slightly lower so that the P/S pump can be used without modifying the hood. Even with the engine mounted in this lower position because the oilpan is so close to the front wheels ground clearance is still excellent.
http://www.k20a.org/forum/showthread.php?t=21985
http://www.k20a.org/forum/show...+ekk2
lsvtec2.0
39
02-24-2005 08:55 PM
Tyson
13
12-24-2003 10:25 PM
