will a OBD2 JDM VTEC solenoid work on a USDM OBD2 Motor & ECU?
I have a USDM B16 motor which is OBD2. I need to get a VTEC soloenoid and I have found one that from a JDM OBD2 motor.
Will this work on the USDM motor with the stock EM1 or ITR Ecu?
Re: will a OBD2 JDM VTEC solenoid work on a USDM OBD2 Motor & ECU? (Vero)
Nobody knows?
I know most JDM ECU's will work just fine, but anyone know if the JDM ECU will work for US emissions?
Go Tigers!
theres two wires that you gotta jump on the ecu, ii forget which ones they are. or you could use the pressure switch from another vtec solenoid. whatever you wanna do!
ek9eli
02-05-2014 09:22 PM
Vero
06-28-2007 04:48 PM
