ITR gauge cluster swap into civic 96 coupe (d16y8 engine) ??
Hello guys !
Can i put the ITR gauge cluster into my civic 96 coupe ??
Is there any modifications that ill need to do ??
I think it looks much better than the CTR cluster!
Thanks.
Thanks.
Re: ITR gauge cluster swap into civic 96 coupe (d16y8 engine) ?? (loverboy)
some how to for 96-00 civic guys:
http://www.merritr.com/gauge.html
or
https://honda-tech.com/zerothread?id=1053318
or
Pic is borrowed from one of the threads
or
or
Re: ITR gauge cluster swap into civic 96 coupe (eg6ajk)
Thanks my friends realy great information !!
Is it matter which gauge cluster spec im using ? (94-97 or 98-01)
Does it depends on which enine swap ill do ? for example if ill do a 99 ITR swap is it matter if im using the 98-01 cluster or the 94-97 ?
What r the advantages of the newer cluster if there any ?
Thanks.
Thanks.
Ditto
Re: ITR gauge cluster swap into civic 96 coupe (loverboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loverboy »</TD></TR><TR><TD CLASS="quote">What r the advantages of the newer cluster if there any ?
Higher tach and speedo.... but it never looks just right in a Civic.
Re: ITR gauge cluster swap into civic 96 coupe (RotiEatter)
I didnt understand what u mean i have looked on them and they have the same tach and speedo??
Any way ill steel didnt get the answers the the other questions (the more important ones) ??
only real difference is that the wiring is alittle different on the back . also i have a 98 dash wire harness already wired for integra cluster that i will sell
Modified by EKlscoupe_98 at 7:12 PM 5/20/2007
Re: ITR gauge cluster swap into civic 96 coupe (EKlscoupe_98)
Do u guys shure it doesnt matter which gauge cluster u choose according the Itr engine year u swap ?
So there is no reason to buy the 98-01 cluster (150$-300$) instead of buying the 96-97 cluster (80$-150$) ??
Why there is such a difference in the prices ?
loverboy
07-01-2009 02:18 PM
dawrenn
13
03-23-2005 11:50 AM
