Ecu problem help !!!
Old May 24, 2007 | 01:35 PM
95civicB16's Avatar
Default Ecu problem help !!!
Ok i have a 95 civic ex. Putting a b16 going obd1. Will the p28 run the engine with out tuning and would it hurt it until i have the money to tune. All the help would be nice. Typically how much would that tune cost.
Old May 24, 2007 | 06:39 PM
95civicB16's Avatar
Default Re: Ecu problem help !!! (95civicB16)
BUMP !!!!
Old May 24, 2007 | 11:24 PM
dannis.'s Avatar
it will run it alright until you can either tune your car or get a chipped ecu. i would just chip it since your probably stock. chiping is cheap varies from 70-150 depending on where its done just look around.
Old May 25, 2007 | 11:09 AM
95civicB16's Avatar
Default Re: Ecu problem help !!! (dannis.)
If you mean no turbo then yes. The intake manifold is obx and will also be running high compression pistons. Everything else is stock.
EG6Marcus
Engine Management and Tuning
Jan 23, 2011 01:15 PM
Da9austinRacing
Jun 11, 2010 02:47 PM
$LiLPooky$
Nov 19, 2009 04:01 AM
KARSON
Mar 4, 2009 04:16 PM
95lscivic
Aug 15, 2006 11:38 PM
