B18C1 into EG throttle cable help
Your still using the GSR throttle body; you can swap it over to a normal throttle cable using an ITR throttle cable and bracket; with switching the throttle body rotor to that of a non gsr one. Or you can leave it how it is cause it works.
Re: (Lippe019)
If you switch throttle body rotor then I believe inlinefour.com has the P73 cable and bracket for 35.00 and that is what I used on my B16 into EG. works flawless.
mrbsponge
03-22-2004 01:50 PM
