h2b guys. help
Old May 19, 2007 | 09:58 AM
3a_eg_hatch's Avatar
Default h2b guys. help
im trying to wrap everything up before i spend all my money in my eg with type r tranny. moneys not an issue
has anyone had problem with hasport mounts?
im going to build the head later this year i want stage 2 axles. do i get b series axles and from who. i was thinking hasport again?
which block? i wanted obd1. which is eaiser to mess with?
OBD1
OBD2 SH
OBD2 TYPE S
e.s.p altenator bracket anygood
quartersportsdrag kit any good if not who
what electrical do i need to do
finally threds would be great on how to i cant look through all the pages ill go crazy after 30 mins
Old May 19, 2007 | 10:20 AM
Bense's Avatar
Default Re: h2b guys. help (3a_eg_hatch)
1. No need for hasport mounts, use the stock b-series mounts.
2. use stock axles and learn how to preload
3. a good rule of thumb, obd1 is always easier to work with.
4. you can't use a SH block with that ATTS junk
5. the type S engine is going to be more money than it's worth.
6. ESP bracket is good, I own one.
7. QSD and Evolution are the two H2B kits that are available, each has their advantages and disadvantages. Read the other threads, I'm not about to engage another H2B war here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3a_eg_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i cant look through all the pages ill go crazy after 30 mins</TD></TR></TABLE>
Then that's your problem, not ours.
Old May 19, 2007 | 09:14 PM
H2B just chillin's Avatar
Default Re: h2b guys. help (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">1. No need for hasport mounts, use the stock b-series mounts.
Then that's your problem, not ours.</TD></TR></TABLE>
Good advise
depending on the kit ...For easy modifications use the obd1 h22a less hassle..
Old May 20, 2007 | 12:43 PM
RotiEatter's Avatar
Ditto
Old May 21, 2007 | 01:30 PM
Default Re: h2b guys. help (RotiEatter)
you guys know where can i get a type r trans or a jdm b series trans
Old May 21, 2007 | 02:45 PM
hpi247's Avatar
try hmotorsonline.com i got my whole swap from them and im pretty satisfied.
Old May 21, 2007 | 07:27 PM
87shytwhip's Avatar
Default Re: h2b guys. help (hpi247)
just to prevent confusion.. the motor will not sit correctly with stock mounts using the evolution kit.. you must use there mounts
B16A3Civic*Eg
May 22, 2006 10:23 PM
E36 Guy
Aug 26, 2005 07:02 AM
VTecLude1994
Jul 26, 2005 01:56 PM
Magnaflow
Aug 15, 2003 07:25 AM
