First K20(RSX) EG swap
I got a friends RSX that was basicly totaled (so i can pull any parts I want from it)
I need some info on how to do it, I've seen the Hasport write up
but I need info on wiring,which ECU to use, axles, if I can put RSX hub and knuckles on the EG hatch,and how to install the shifter and transmission and some other little stuff
Re: First K20(RSX) EG swap (SupraRXZ)
This is the best refferral I can give to you. http://www.k20a.org
