recalibrate TPS??????anyone?
tried searching only found one thread.
I had put in a new TPS since the one before on it was fawked.
anyways, someone i came across said i should recalibrate it because it looked off and i do feel a difference maybe in my head with performance and the idling
I do have a volt meter but how should i approach it?
any info would happily appreciated
Re: recalibrate TPS??????anyone? (h8ted ek)
anyone?
how can tps affect my performance if its not recalibrated correctly? i do know that i used to pull hard when it was working
MiG-21 superfan
you want it to be .5Vish at idle and 4.5V at full throttle. you can set this by rotating it until you get the settings you want; at that point you tighten it down and check to see if the settings held.
LS AzZkIkr
05-18-2007 07:03 AM
