Anyone in the ORLANDO area good with wiring the engine harness?
anyone good with wiring engine harness...my check engine light came on and it throws a code 22 which is the vtec oil switch but i unplug the ground the unplug the switch and put them back on still the engine light is still on and still throws code 22 so i think the engine harness wire is loose...
Are you obd1? If you are just connect pin a4 to pin d6 on your ecu. Just make a jumper wire. Look on phearable .net for more info in the tech section.
-Brax
-Brax
NipponRacing
06-18-2002 05:49 PM
