GSR swap Ek, what upper radiator hose?
Re: GSR swap Ek, what upper radiator hose? (cheesee)
The GSR radiator hose is to be used, but the problem with using the stock civic radiator is the inlets are of a smaller diameter but if you tighten it down properly then it shouldn't be much of a problem. If your using the screw tightening clamps, then you might want to switch them with the push and lock type.
Re: GSR swap Ek, what upper radiator hose? (rockthevote)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockthevote »</TD></TR><TR><TD CLASS="quote">The GSR radiator hose is to be used, but the problem with using the stock civic radiator is the inlets are of a smaller diameter but if you tighten it down properly then it shouldn't be much of a problem. If your using the screw tightening clamps, then you might want to switch them with the push and lock type. </TD></TR></TABLE>
good job repeating/copy-pasting what someone said on the other forum. go get your post count up some where else.
invisible
12
05-30-2007 03:41 PM
Flamenco-T
02-25-2003 12:53 PM
