b20b clutch
Old May 18, 2007 | 06:56 AM
94 ls teg's Avatar
Default b20b clutch
got a b20b swap for my integra and what clutch do i use? any help please
Old May 18, 2007 | 10:39 AM
eg6ajk's Avatar
Default Re: b20b clutch (94 ls teg)
it is dependent on the year of your tranny. 90-1 use 90-1 B16/b18 clutch disc/flywheel combos. 92+ cars can run b18b/c or B16a clutch/flywheel combos.
with exception of pistons/rings and bore size B20B is a 96+ LS!
Old May 18, 2007 | 10:44 AM
94 ls teg's Avatar
Default Re: b20b clutch (eg6ajk)
94 ls tranny
Old May 18, 2007 | 10:49 AM
eg6ajk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94 ls teg &raquo;</TD></TR><TR><TD CLASS="quote">94 ls tranny </TD></TR></TABLE>
92+ cars can run any 1992-2001 b18b or b18c1 or 92+ B16a/b17a clutch/flywheel combos, its up to you. Best one to get would be B18C1/5 as in GSR or ITR, as it holds most power without slipping.
Old May 18, 2007 | 11:33 AM
TwoRedEGgs's Avatar
If you are getting a new clutch you may as well get a decent aftermarket one. I'm not going to tell you which one is better or what to get, there are alot of choices. I would keep if pretty basic; sprung full face with street presure plate. That would be fine on the street and will not take all your strength to use it.
demian22
Jun 20, 2008 02:38 PM
Greddy Dantegra
Jan 4, 2006 06:28 AM
bambam
May 3, 2004 08:22 AM
bhu
Jul 25, 2001 07:40 AM
jbsadler
Jun 26, 2001 10:39 PM
