what clutch and axles? ( h2b )
Old 06-16-2007, 01:12 AM
Winlight's Avatar
Default what clutch and axles? ( h2b )
what clutch and axles are stong enough for an h2b build?i dought ill have more then 250 hp to the wheels but i want a clutch and axles that will hold up to high rpm launches on slicks.
Old 06-16-2007, 01:26 PM
AllMotorRandy's Avatar
Default Re: what clutch and axles? (Winlight)
Old 06-16-2007, 02:04 PM
oneslowstd's Avatar
Default Re: what clutch and axles? (AllMotorRandy)
god I want H2B bad! Sorry im no help but H2B's rule!!
Old 06-16-2007, 03:04 PM
Winlight's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorRandy &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>is that flywheel for sale?if it is,then how much does it way and what do you want for it?
Old 06-16-2007, 08:13 PM
Go Tigers!
Bense's Avatar
You should read the FAQ stickied at the top of this forum, it tells you everything you need to know.
Old 06-16-2007, 08:45 PM
Winlight's Avatar
Default Re: what clutch and axles? (Bense)
im asking about brands,i know to use the b sieres axles and clutch.im just asking about the best parts for my build
Old 06-17-2007, 02:43 AM
numbnuts22715's Avatar
I like my ACT xtss clutch, so I would recommend act.
As for the flywheel, i have a fidanza, i dont know how much of a difference a different brand of flywheel could make...
Old 06-17-2007, 02:52 AM
Winlight's Avatar
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">I i dont know how much of a difference a different brand of flywheel could make...</TD></TR></TABLE>niether do i,thats why i didnt ask about a flywheel
Old 06-17-2007, 09:19 PM
Default Re: (Winlight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">I like my ACT xtss clutch, so I would recommend act.
As for the flywheel, i have a fidanza, i dont know how much of a difference a different brand of flywheel could make...</TD></TR></TABLE>
Well if you look closer to the 2nd picture i posted.... you'll notice that the center protrudes out more..... thats to compensate for the h2b mounting plate. This means that you will not have to use the flywheel spacer or the extended bolts provided with the kit.
NO SPACER + STOCK FLYWHEEL BOLTS = ZERO PROBLEMS Contact Luis @ Clutch Masters if you have anymore questions. This flywheel Is available for a twin disc or standard pressure plates.
Old 06-18-2007, 03:03 AM
h2bv8killa's Avatar
Default Re: (AllMotorRandy)
as far as the axles...i wanna say that factory b series will hold up to 240 ft lbs of torque but don't quote me on it...thats what i'm using on mine. and i'm getting an act clutch this week!!! H2Bs RULE!!!!!
Old 06-18-2007, 06:56 PM
HeikDiesel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorRandy &raquo;</TD></TR><TR><TD CLASS="quote">Well if you look closer to the 2nd picture i posted.... you'll notice that the center protrudes out more..... thats to compensate for the h2b mounting plate. This means that you will not have to use the flywheel spacer or the extended bolts provided with the kit.
NO SPACER + STOCK FLYWHEEL BOLTS = ZERO PROBLEMS Contact Luis @ Clutch Masters if you have anymore questions. This flywheel Is available for a twin disc or standard pressure plates. </TD></TR></TABLE>
Are they having problems with the longer bolts?
Old 06-18-2007, 09:13 PM
jozy22's Avatar
IM USING AN ATION 6 PUCK SPRUNG AND A FIDANZA LIGHTENED FLYWHEEL NO PROBLEMS AT ALL. AS FAS AS AXLES GATORS
Old 06-19-2007, 05:59 PM
Alchemist's Avatar
Default Re: (jozy22)
Action Clutch 1MS or 1MD. Let me know if you have any questions about the clutches and I'd be happy to help you out!!!
Old 06-20-2007, 04:04 PM
skunked's Avatar
Default Re: (HeikDiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">
Are they having problems with the longer bolts?</TD></TR></TABLE>
no there has not been any issues.
ganjasnack
07-21-2008 01:47 PM
maxspeedhonda
01-31-2005 08:17 PM
91glassycrx
05-17-2004 07:40 PM
egracer44
08-09-2003 12:11 PM
Quick Reply: what clutch and axles? ( h2b )
