Just Failed BAR ....
Old May 18, 2007 | 03:20 PM
.Thomas's Avatar
Default Just Failed BAR ....
Emissions ... great
But no data link cable, also, get this new this week NO ECU ADAPTERS
so now i have to put an integra chassis harness into my civic,
Also passed emissions, but no odb2 cat so i failed that too
Old May 18, 2007 | 05:00 PM
mdj_ge's Avatar
Default Re: Just Failed BAR .... (TanCar)
what's the year/make chassis and motor???
Old May 18, 2007 | 10:40 PM
.Thomas's Avatar
Default Re: Just Failed BAR .... (yangja)
92 civic, 96 motor
Secondary 02 hooked up and everything
Old May 18, 2007 | 10:41 PM
.Thomas's Avatar
its FS if anyone wants it, 1800 takes it.
Old May 19, 2007 | 09:18 PM
H2B just chillin's Avatar
If its a 92 civic why not set it up as obd1 unless it's a type R ... If not a type R just change the manifold out .....Btw what 96 engine do you have? B,H,D,K Series...
Old May 19, 2007 | 11:35 PM
FredoTheChimp's Avatar
Default Re: Just Failed BAR .... (H2B-CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2B-CRX &raquo;</TD></TR><TR><TD CLASS="quote">If its a 92 civic why not set it up as obd1 unless it's a type R ... If not a type R just change the manifold out .....Btw what 96 engine do you have? B,H,D,K Series...</TD></TR></TABLE>
If it's a 96 engine I'm pretty sure he'd have to run OBD-II for BAR.
Old May 20, 2007 | 12:51 AM
.Thomas's Avatar
Default Re: Just Failed BAR .... (FredoTheChimp)
B series, and yes, i do have to run obd2
Old May 20, 2007 | 07:49 AM
Alchemist's Avatar
Why dont you just take it to another station that is not as strict.
Old May 20, 2007 | 08:38 AM
.Thomas's Avatar
Default Re: Just Failed BAR .... (Alchemist)
thats what i might do, but the next station is 1.5 hours away, and i dont know how strict that is ...
Old May 20, 2007 | 11:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TanCar &raquo;</TD></TR><TR><TD CLASS="quote">thats what i might do, but the next station is 1.5 hours away, and i dont know how strict that is ...</TD></TR></TABLE>
Or re-pin and hook up the car permanently for OBD-II. Probably would be a last effort situation, but it's really not that difficult at all. Good luck to you though man, I know how much of a pain getting through the BAR certification process can be.
Old May 20, 2007 | 04:29 PM
"Correction" I've done this many times you can set it up as obd1 ....use obd1 ecu and intake manifold... it will pass visual ....everything else works the same..
well maybe only for the b18c1 GSR and b18b LS
for the b16a1 , b16a2, and b16a3 it has to be set up the same year as the engine...........but for the 1.6L bar sticker we ref the single cam 1.6L V-tec engine
and then throw in the b16... This the only info i got for you...
Old May 21, 2007 | 08:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2B-CRX &raquo;</TD></TR><TR><TD CLASS="quote">"Correction" I've done this many times you can set it up as obd1 ....use obd1 ecu and intake manifold... it will pass visual ....everything else works the same..
Yeah I think everything comes down to the ref. My sticker clearly specifies "b18c5" on it in addition to the 1.8 Acura Integra.
Old May 22, 2007 | 06:44 PM
UNLESS HE HAS A B18C5 TYPE R WHICH ONLY CAME OBD2
BUT THE B18C1 B18B1 ALSO CAME OBD1
BTW WHICH B SERIES DO YOU HAVE B18C1,B18B1,B18C5,B16A? ECT.. THAT WILL HELP....
lrayford
May 2, 2009 12:32 PM
craigek4civicpwr
Suspension & Brakes
Jun 26, 2008 01:36 AM
CleanLikeJdm
Nov 28, 2005 12:34 PM
quicksol95
Mar 11, 2004 09:08 PM
