What numbers will this make ?
i KNOW I KNOW most of you are going to say dyno it and find out but im really anxious to see what you guys think. Im putting this build together now wanted to see what kind of power you guys think it will make.
h22a4 block and head
honed by endyn
Aem cold air intake
66mm TB bored by maxbore
Euro r intake bored by maxbore
Blocked and removed EGR valve
Hondata headsheilf gasket
Coolant line loop
Skunk2 stage 1 cams
AEM cam gears
Supertech flat valves
Supertech titanium retainers
Supertech valve springs
DC header with 2.5 inch collector for now looking into RMF
Test pipe
Tanabe hyper medallion exhaust
one layer OEM headgasket
Prelude type s piston standard size
Eagle hbeam rods
m2a4 trans
XTD prolite 10lbs flywheel
XTD stage 3 clutch
Fluidyne Radiator
UR ultra r crank pulley
Kaizenspeed balance shaft removal kit
Walbro 255 fuel pump
Car will have EVAP system removed and ATTS removed. Also no power steeing or AC. Car will be tuned on Hondata s300 by evans tuning
Car also has energy suspension motor mount inserts and ingalls engine torque dampener.
Modified by lude98SH at 8:25 PM 2/16/2007
honed by endyn
Aem cold air intake
Coolant line loop
Skunk2 stage 1 cams
AEM cam gears
Test pipe
Eagle hbeam rods
m2a4 trans
XTD stage 3 clutch
Fluidyne Radiator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Nick M »</TD></TR><TR><TD CLASS="quote">4) E-Racing/Bench Racing/Guess my 1/4 or HP
There is no place for it here, it is not productive, frequently leads to arguments, and is generally pointless. Go find a dyno or a drag strip.</TD></TR></TABLE>
Taken from the forum guidelines.
Re: (Combustion Contraption)
oo sry i did not see that. I never posted something like this really i wasnt aware. Like i said sorry if i was aware of that rule i wouldnt have posted this. I should have read those guidlines.
Whoa!
He admitted he didnt read them and apologized before insulting or starting a flame war! That in itself deserves some applause. Not being sarcastic either.
Look into Endyn working your head over, if you can afford it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">Whoa!
Haha well im here for help not to make any enemies. About the head well im trying to do just a semi mild build and trying to keep the machining costs down alittle.
Re: What numbers will this make ? (lude98SH)
if you get the motor mount inserts you dont need the engine torque damper it a waste of money. then if you buy the torque damper you dont need the inserts.
Fastblacksi
01-07-2007 11:49 PM
meanEG
25
06-17-2004 05:32 AM
