LSvtec w/ block girdle? yay or nay?
Old 08-11-2007, 06:33 AM
chippy's Avatar
Default LSvtec w/ block girdle? yay or nay?
I used the search feature, but couldn't find anything with it. I was just wondering if I would even need a girdle for the ls bottom end. There are some FI guys making 500 or so on just maincaps w/out the girdle.
Portflow GSR Head
B18a1 block-
ACL bearings
LS Rods with ARP rod bolts
PR3 pistons 81.5mm
ARP Main studs <-- (if getting girdle i dont' think i will be getting the main studs)
So in the end. Would I need a block girdle, or can i just use the LS main caps and call it a day?
Old 08-11-2007, 09:19 AM
killerpenguin21's Avatar
Default Re: LSvtec w/ block girdle? yay or nay? (chippy)
without a girdle i wouldnt rev over 8k.
Old 08-11-2007, 09:39 AM
reactiondc2's Avatar
Default Re: LSvtec w/ block girdle? yay or nay? (killerpenguin21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chippy &raquo;</TD></TR><TR><TD CLASS="quote">I used the search feature, but couldn't find anything with it. I was just wondering if I would even need a girdle for the ls bottom end. There are some FI guys making 500 or so on just maincaps w/out the girdle.
Portflow GSR Head
B18a1 block-
ACL bearings
PR3 pistons 81.5mm
ARP Main studs &lt;-- (if getting girdle i dont' think i will be getting the main studs)
</TD></TR></TABLE>i wouldnt worry about the girdle or the main studs...ive twisted past oem ls/vtec builds up to 9500 with zero problems...just my .02
Old 08-11-2007, 02:38 PM
all-mtr-teg's Avatar
i have an oem gsr girlde and main caps for sale if you do decide to use it.
Old 08-11-2007, 02:42 PM
cartune network's Avatar
Default Re: LSvtec w/ block girdle? yay or nay? (all-mtr-teg)
i would run a girdle. rather be safe than sorry. every build is different so i would run one especially if u plan on reving it high.
Old 08-11-2007, 02:52 PM
1.8L_allmotormilitia's Avatar
some say its needed some say its not needed. i hope this helps.
edit: but it also matters how high you rev it.
Old 08-11-2007, 03:05 PM
chippy's Avatar
Default Re: (1.8L_allmotormilitia)
it's a daily driver with the occasional rev to redline
Old 08-11-2007, 03:23 PM
Default Re: (chippy)
so im just wondering...how many people have seen an engine failure that was directly caused by the lack of a main girdle?...
Old 08-11-2007, 04:08 PM
93egallmotor's Avatar
i rev my ls/vtec close to 10,000 rpm daily ( no girdle)
Old 08-11-2007, 06:18 PM
honda_ef9's Avatar
dont you have to get an align hone with using gsr mains? but i guess you would have to anyways if you got arp mains
Old 08-11-2007, 08:41 PM
chippy's Avatar
Default Re: (honda_ef9)
not arp main. just main bolts i don't think you need to get it align hone for main bolts. Anywho how much does it usually run to get a align hone if i do go that route. I'm thinking i can be safe without the girdle. There are LS turbo's that are making 350hp without using a girdle.
Old 08-12-2007, 06:25 AM
the power isnt the issue, the rpm is.
i couldnt even find a machine shop within two hours of me that had the machine to do an align hone so i went without and just checked for roundness.
Old 08-12-2007, 05:34 PM
NJIN BUILDR's Avatar
Honda's have a very stable stock mainline.Your stock rods will fail long before the stock mainline gives you a problem.And your stock rods w/arp bolts should be fine for your build.
Old 08-12-2007, 06:10 PM
G2K
G2K's Avatar
Default Re: LSvtec w/ block girdle? yay or nay? (NJIN BUILDR)
To the OP, the ls block is pretty good on its own. I have myself taken ls motors above 9k on a reg basis without the girdle and the crank and bearings looked fine when the motor was torn down(reg. maintance plan). The biggest thing is to make sure the block is align honed, and mic the crank for straightness. If everything is straight and within spec, your good to go
Also if you install ARP mainstuds, you need to have the bottom end align honed. The ARP's will cause the mains to distort. Its a given anytime you install studs in a bottom end, you need to check it to make sure its within spec. And before anyone says that if the ARP's distort the mains, then there no good, everyone in the racing industry that has a clue about installing ARP's will tell you they align hone the mains.
And of course if you do decide to install the girdle, wether it comes from golden eagle, erl, or even a stock gsr girdle, remember that you still need to have all the mains align honed.
Good Luck.
Old 08-12-2007, 06:13 PM
G2K
G2K's Avatar
Default Re: LSvtec w/ block girdle? yay or nay? (G2K)
Oh and I almost forgot, the stock main bolts are strong, hence why teams like Eggum Racing(well over 1000HP) run stock bolts in the mains.
Just food for thought.
Old 08-12-2007, 06:15 PM
chippy's Avatar
ah interseting. Thanks. Maybe i'll just stick to the stock bolts and and main caps. Run it without a girdle.
Old 08-13-2007, 09:50 AM
b20beast978's Avatar
thats what i would do
Old 04-29-2020, 08:54 PM
Sergio Flores's Avatar
Good Luck.
question, why does everyone say you have to lined honed you mains, when non of the seller that sell these girdle suggest getting line honed? thanks
Old 04-29-2020, 09:19 PM
JRCivic1's Avatar
If the sellers told you extensive work was necessary to properly fit the girdle, how many would they sell ?
Old 04-29-2020, 09:39 PM
you have a point thank you.
Old 04-30-2020, 10:19 AM
K20.ek's Avatar
Balance the rotating is a great option to do if you plan on reving high.
92eg6lsvtec
07-22-2005 12:40 PM
SleepinTeg
05-31-2005 07:03 AM
94dxt
04-27-2005 08:13 AM
KiNG $h!t
08-14-2003 02:00 PM
Quick Reply: LSvtec w/ block girdle? yay or nay?
