ITR pistons in LS B18a motor
Old 08-12-2007, 09:23 PM
Nisif's Avatar
Default ITR pistons in LS B18a motor
A friend of mine was wondering if the above combination will work. I'm assuming the itr pistons will work in b18a motor (using the b18a non vtec head). If piston-to-valve clearance isn't an issue, is there anything that needs to be done to the rods for the pistons to fit? TIA
Old 08-13-2007, 08:54 AM
all-mtr-teg's Avatar
Default Re: ITR pistons in LS B18a motor (Nisif)
some machining will need to be done on the rods, but i want to know minimum valve-to-piston clearance also.
Old 09-12-2007, 05:06 PM
CW96's Avatar
Default Re: ITR pistons in LS B18a motor (all-mtr-teg)
I need to know too, BUMP
Will this work with a NON-VTEC b18a/b or b20?
Old 09-12-2007, 07:33 PM
J_White's Avatar
Bump. Hopefully you get the answer you were looking for. Wish I could help gooluck.
Old 09-12-2007, 07:51 PM
kartman5's Avatar
Default Re: (J_White)
My son built his LS 95 with ITR pistons with a slight overbore and it runs great.
No changes made to the rods. Good luck!
Old 09-13-2007, 06:21 AM
CapnToll's Avatar
Default Re: (kartman5)
He didn't have to mill the rods 1mm on each side to fit ITR pistons? Usually the thinking is that only JDM B16 P30 pistons will fit on LS rods without any modification necessary.
Old 09-13-2007, 06:45 AM
h22_SOL's Avatar
Default Re: (CapnToll)
DOES ANY HAS A DYNO CHARTS WITH THIS SWAP?
i wanna noe how much did the ls push the ITR pistons.
and wats the diff beteween ITR and CTR piston?
-bruce
Old 09-13-2007, 06:52 AM
h22_SOL's Avatar
Default Re: (h22_SOL)
another question..
if i slap a gs-r head on my ls swap with itr piston.
will that to be high of CR to be a daily driver??
please let me noe.. before i do it and BAM it blows..lol
Old 09-13-2007, 11:04 AM
TehMan's Avatar
i had a b18b with a fully built head including 404 cams...the block had jdm itr pistons in it with ls rods...ran GREAT
Old 09-21-2007, 08:07 PM
CW96's Avatar
Default Re: (TehMan)
can someone confirm ITR/CTR pistons will work with a STOCK B18a/b motor
will there be ANY milling/oversizing involved?
Old 09-22-2007, 06:08 AM
ctr power's Avatar
Default Re: (CW96)
yes it will work
Old 09-22-2007, 10:48 PM
DB1_559's Avatar
Default Re: (CW96)
CTR pistons only,will require some shaving the ls rod
Old 09-23-2007, 01:50 PM
wascly's Avatar
Default Re: (DB1_559)
Just do p30 or pr3 pistons. Those won't require any modifications and will give higher CR than the p73 pistons. The PCT pistons will give about 12.5:1 with an LS head.
The Vtec Pistons have deeper valve reliefs so there is no need to worry about piston to valve clearance. Plus non-vtec cams tend to have mild lift characteristics.
These pistons will NOT work in a b20 block. 81mm vs. 84mm
I have an LS block w/ p30 pistons and a b16 head. It is great for a DD. A p72 head will yield about .1 to .2 higher comp ratio.
PR4 and PR3 rods are wider than p72, p73 and PCT rods. Hence the modifying of the pistons or rods whenever you choose to mix/match combos.
Anything is possible with a skilled machine worker/shop. Besides you will have to get the wristpins pressed into the rods anyway.
Old 09-24-2007, 02:29 PM
CW96's Avatar
Default Re: (wascly)
What OEM combination will require no machine work/modifications?
And or what will be the easiest OEM setup with PR3 or P30 pistons?
EDIT: with a b18a/b head
Old 09-24-2007, 05:57 PM
ls-vtec-delsol's Avatar
ls rods dont need to be milled for oem itr pistons. And your valve clearance is good-to-go. I ran with this set up for a while. But theres really no power. If you want more power after that setup, just go ls vtec. blocks already done.
Old 09-24-2007, 07:05 PM
CW96's Avatar
Default Re: (ls-vtec-delsol)
But I understand CTR/B16 pistons have a higher compression as stated above; also...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wascly &raquo;</TD></TR><TR><TD CLASS="quote">Just do p30 or pr3 pistons. Those won't require any modifications and will give higher CR than the p73 pistons. The PCT pistons will give about 12.5:1 with an LS head.
Anything is possible with a skilled machine worker/shop. Besides you will have to get the wristpins pressed into the rods anyway.</TD></TR></TABLE>
Old 09-24-2007, 09:04 PM
wascly's Avatar
Default Re: (CW96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW96 &raquo;</TD></TR><TR><TD CLASS="quote">But I understand CTR/B16 pistons have a higher compression as stated above; also...
Exactly, just get some p30s from Hmotorsonline and call it a day. Done.
Old 09-25-2007, 04:01 AM
CW96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wascly &raquo;</TD></TR><TR><TD CLASS="quote">Exactly, just get some p30s from Hmotorsonline and call it a day. Done.</TD></TR></TABLE>
OK, so no modifications needed to any of the head or block?
Old 09-25-2007, 04:23 AM
Mad Scientist
mmuller's Avatar
Default Re: (CW96)
no
Old 09-25-2007, 12:55 PM
Suspetise...
Stinkycheezmonky's Avatar
Default Re: (mmuller)
RS Machines also sells a variety of pistons for non-VTEC use with ITR/CTR/B16 etc. designs. That includes 84mm pistons, in case anyone is wondering.
Old 05-13-2008, 03:10 AM
ceyazzie's Avatar
i works perfect. i have a ls/vtec build with ITR pistons.. had machine work done.. great daily driver with A/C...
EGgarniEG
10-20-2007 11:39 AM
lscoupe
05-18-2005 02:20 PM
compwc18
10
03-02-2004 08:15 AM
DOHCon15s
04-11-2003 06:46 AM
velocitysir
06-09-2002 07:05 PM
Quick Reply: ITR pistons in LS B18a motor
